Hi
I have a local installation of SQL, Archiveserver and Databaseserver, and a local file vault to test functionality and basically teach myself PDM.
I have come across a problem with configuring SMTP for sending notifications.
The error message is "The server was not found" - for the record, i am using the "Test Settings" button in PDM Administration program.
I have checked a few things, including telnet to SMTP server (ISP's server) both on name and IP (smtp.songnetworks.no/85.19.210.243) on port 25 which works fine.
I have also tested sending an email with the script given in this thread https://forum.solidworks.com/message/267894#267894 and that works fine. (Thank you Tyler) The exact same settings does not work in EPDM.
I have also tested the settings in Outlook successfully.
I have turned off local firewall and antivirus, to rule them out.
I have also tested from another network, but then i get another error saying "The system has detected a possible attempt to compromise security. Please ensure that you can contact the server that authenticated you." I have yet to figure that one out...
I have also checked that the Vault is listed in ConisioMasterDb (https://forum.solidworks.com/message/211353#211353)
I can not ping the SMTP server, but for that matter i cannot ping anything else either, outside the local network, but every website or service online works just fine.
Nothing in PDM logs is helpful, neither is Windows event viewer.
In a last desperate attempt i have also disabled IP v6 on my computer, giving me a better result pinging my PC, but nothing changed with this problem.
I have also checked s-046232/015424/014168 in the varportal, and checked and corrected what i found applicable.
This is EPDM 2012 SP1, on Windows 7 x64.
Any idea is very welcome!
