How to create or design HOSE in Routing?
Discussion created by Guest on Jul 6, 2006
Latest reply on Feb 16, 2007 by Merry Owen
Yes, you're on the right track, Use a flexible tube part for the tube and make sure the route properties are all set to flexible. Ideally you should create suitable end fittings too. The route can then be modelled using splines or use autoroute.
Development Manager - Routed systems.
