I am trying to install the epdm web client but I keep getting the error 1925 “you do not have sufficient privileges to complete this installation for all users of the machine. Log on as an administrator and then retry this installation”. The problem with this is that I am an administrator there in no other accounts on this computer? I am on windows 7 64bit
Hi Jeremy,
are you trying to install web server or a webs server client?
If you already have EPDM WEB SERVER Online.
1. Just go to the Web addresse of your EPDM Web Server.
2. Enable all activeX Controls.
3. If you still face any problem you can manually install Web Client using install.msi found in Your Server (Where you installed EPDM) somewere in c/prog files/epdm/web/install/install.msi....i dont have epdm right now.
Take the whole WEB Folder and run install.msi
Regards
Ravi T
