I would like to be able to use the Search tool to create a file list of every document that is referenced by a selected document. This would be the same list as shows up in the Contains tab, but as a search result it would be a fully functional file list, like in Windows explorer file pane. The Contains tab itself lacks many of the capabilities I need, so it is not sufficient by itself.
Running a search for documents referenced by the selected document would be perfect, but I don't see a way to do it...
Brian, sorry for taking so long to respond. You would not be able to do that using Reporting Services. The best you can do with that would get you the same functionality as an email notification. Open, View, Get Latest, Properties, History, and Browse to.
EPDM 2012 has one improvement in the Contains list of files. It has two Browse To commands. The "Browse To in New Window" is like the old Browse To command. The new Browse To switches Windows Explorer to the file selected in the Contains list.
The only way I see of doing what you want would be a custom app.
