I would like to move a number of parts that are currently in the top level assembly into a (new) subassembly. I tried making a copy of the top level assembly (save as/make copy) to form the subassembly. I can easily remove the parts from the top assembly and insert the new sub-assembly, but the associated drawing files loos all their dimension connections to the parts. They are the same part files, but now inserted by way of the sub-assembly.
Is there a way to move the parts from the top level assembly into a new subassembly file that will not make the drawings loose the dimensions to the parts? The parts need to retain all their mates, all of which are to a single part that would be moved into the subassembly, so "in theory" I would only need to define the 3 mates to put the subassembly back into the main assembly.
Thanks - Greg
