Has anyone else experienced this or found a fix...
I have several drawings that will not reload to my most current template so that revision data will populate correctly.
If I make new parts/drawings with the new template everything works beautifully but if I try to revise an existing drawing and load the most current template, it is as if solidworks pulls the old one from memory no matter what I do.
Did you try to replace the template?
