2 Replies Latest reply on Jan 19, 2012 10:47 AM by Lenny Bucholz
    Objects cut by a section line should have a thicker line weight
    Bill Lacey
      I've been looking, but I don't know how or if I can automate this. Currently when you create a section view all of the objects have the same line weight. What I want to happen is to have the boundary of all objects that are cut by the section line to have a thicker line weight (0.50mm) and all of the background lines to have a thinner line weight (0.18mm or maybe even 0.13mm). Right now with the section views it is nearly impossible to differentiate between an object that is cut and the background objects. Am I missing a setting, or is this not possible in SW?
