Is there a way to "flat pattern" of the sheet metal part being twisted (using flex command)?
Thx, Chris
No way other than making configurations. One with flex and one without flex.
Chris,
Actually you can. You just use the lofted bend feature to pull this off.
Jeff
Would be most interested in seeing this in a '11 version. Have similar requests here on occasion.
SP5 for '12 is a while coming yet before we upgrade here.
Thanks.
Here is a 2011 version.
Awsome - Thanks, Jeff
Too simple, thats perfect. Thanks for the example!
Can u create a helical twisted(screw) sheetmetal with a flatpattern?
I might be wrong but AFAIK, you can only "flat pattern" a sheet metal part using the commands included in the sheet metal menu
