Hello everyone, help needed!
I have a spline with X amounts of points on it (refrence geometry --> points).
What i want to do is add planes to the points which are normals to the spline.
I recored a macro of the action, if i change the "Point12" to Point11 and run the macro again it makes the plane.
What i want the macro to do is to add points to the spline (asks how many points) and add planes to the points automatically.
Ive never done any programming so i dont know how to do it, help would be greatly appreciated, thanks in advance!!
Picture and macro code below, macro only includes adding a plane:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Spline1@Sketch1", "EXTSKETCHSEGMENT", 0.04562819180932, 0.05035802922642, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Point12", "DATUMPOINT", 0.0428160235158, 0.04836573865836, -0.005791574549988, True, 1, Nothing, 0)
Dim myRefPlane As Object
Set myRefPlane = Part.FeatureManager.InsertRefPlane(514, 0, 4, 0, 0, 0)
Part.ClearSelection2 True
