I have read several threads that come close to addressing this issue, but don't quite "hit the nail on the head". Here is the issue I am running into:
I will use the hypothetical assembly that contains a part with two configurations (I will call it "Part A"). Part A has a left hand and right hand configuration. When I check the assembly out of the ePDM vault, I immediately get a warning that I am changing Part A which I do not have checked out. Once the assembly loads, I will reload the part. This makes no difference because SolidWorks still views the configuration of the part in the assembly which is not the "active configuration" as a change to the part which must be saved. Since I have two configurations in the assembly I can never get the assembly to come in "clean" with no errors or warnings.
Since I am fairly new to ePDM, I am hoping that maybe I am missing a setting somewhere that will stop SolidWorks from viewing a configuration change as a change to the file. Some of our large assemblies have many parts with multiple configurations (fasteners) which leads to a large number of warning messages. I know that I can check the box that says "do not show message again", but I want that message to show up if there is a legitimate file change.
Maybe I am being too nit-picky, but I want my parts and assemblies to open without the "needs saved" asterisk appearing immediately after opening. Before we had ePDM, it was just an annoyance but now I am getting warning messages.
I am running SW'10 SP 4.0, HP Z200 i5 3.33 GHz processor, Windows 7 SP1, 64 bit, 12 GB RAM. NVIDIA Quadro 2000 video card.
I am having the exact same issue with our new implementation of solidworks and ePDM. I have a folder in our vault designated "Hardware Library" and in it I have placed several design table parts that control our common hardware and that folder location has been added as a design library. The issue I am having sounds identical Shan's in that when I drop a design table part into my assembly and select the appropriate configuration it is telling me upon check-in that I am attempting to save a part that is not checked out (the library part). I am sure that either the way I have defined the assembly or part is not correct because it would seem to me that the point of having library parts such as screws/washers/pins etc should be that they remain unchanged by the user. Looking for an answer too.
SW 12, ePDM 12
