Is there a way to copy with the triad by entering exact value? I am in a 3d sketch mode and want to copy part of the sketch to another place and when I select the copy command it comes up with the “3d Copy” dialog and the triad. I can pull on the arrows of the triad but I can’t place the copy exactly where I want it because I can’t type in value for the triad.
With the 3d sketch open go to Tools>Sketch Tools> Copy this should give you the 3d sketch copy properties and allow you to translate in x,y, and z by typing in the values for each. If you click in the translation reference box the option to key in the values will go away.
