Hi, is it possible to have a single part populate 2 or 3 BOM line items? I often run into this problem where I have a part and mounting hardware kit, two seperate part numbers, but I don't want to go through the extra effort of dropping the "hardware kit" into the assembly and mating it all up, etc...if possible, I want the part to just drive a second line item (mounting hardware kit) in the BOM whenever I use the part...is this possible? I also run into this problem when I have designed an assembly with 4 or so complex parts and I use a "mock-up" simplified single part to represent all 4, but I would like them to drive 4 line items in the BOM...is this possible?
Thanks!
Aron
Aron,
Are you talking about one component in two seperate BOM's in two different drawing files
or the same?
Can you post some images describing what you are looking for? I am having a hard time following your words understanding
exactly what you are looking for.
Are configurations involved as well? That plays a huge part in this as well in how you lay out your BOM.
