Clicking "Open as CSV file" on the Contains Tab of an assembly shows a field/column called "Level" on the left by default. I want to add this same "Level" information to my BOM view so that the "Leve" field/column appears when I extract the BOM in excel using the "Open As CSV file". Does anyone know how to do that?
I tried adding the "Level" variable to my BOM view but it doesn't do it. The "Level" fiels are empty (in the BOM tab and in excel).
Thanks for your help!
Which version of EPDM?
In EPDM 2012, if the BOM goes deeper than one level you will be asked if you want to add a level column.
