I have a sheet metal part w/ several perf patterns. The assembly level adds fasteners, nothing else. The part has only the default config. The assembly has two configs: default and Hide Perfs. Once the the perf patterns are suppressed in the Hide Perfs config, they remain suppressed in the default config. What am I missing?
Thanks for all feedback,
Roger
Roger
You are right. Instead, select the part in the feature tree, hit the properties icon, and edit the part config used. Use the "specify config" option to do each assy config.
This is all easier in a design table, but you have to set that up.
Dwight
