1 Reply Latest reply on Jan 6, 2012 5:49 PM by Timothy Holman
    Exporting Equation Driven Curves
    Mattias Vangbo
      I have a couple of equation driven lines that drives the shape of my part. When I try export to dxf it appears as if the curves gets broken up (approximated) into segments of some length (i.e. as imported into my CAM, but also if i open it in Adobe Illustrator). Now, the resolution of the approximation is not sufficient for my needs (actually it is the sharp cornerns that is my main concern).
      So, would anyone know if the accuracy in the (assumed) conversion is a setting I can find somewhere, or even better - is there a convert-to-splines-funtionality available anywhere?
      Mattias
