Solidworks to Modo Camera
Question asked by Abhinav Chauhan on Jan 6, 2012
Latest reply on Jan 11, 2012 by Rob Rodríguez
Hello.  Not sure this is the correct place to put this.
I am trying to create a composite of different renders of the same part.  i've rendered out images in SWX and the final image i want is a wireframe render similar to the contour line but the hidden edges also get lines rendered.
This can be done in modo by exporting out to ngons so i can get uniform lines.
Now i have opened the swx model in modo and have also imported the polygon model.  Using the imported swx camera in modo I have then rendered out the polygon model using the segmented contours feature and getting the image i required.  When i went back to my photoshop composite, the modo render didnt quite match up with the swx renders.  the modo render was very slightly larger and there was a slight perpective change.  I know that i didnt alter the camera settings and i assumed that the camera would be imported as is.
My question is, is the imported swx camera in modo exactly the same as the swx camera or do i have to change something after import.  I saved the image as the same resolution as the other renders.
The easiest solution for this is to re-render all the images in modo.
Abhinav
