I am trying to make a round spherical expanded metal screen assembly 16" in diameter with around a 24" spherical diameter, .079 diameter metal screen w/1" square holes. A .25 inch round metal ring is attatched to the outer diameter by wraping overlaping metal around the ring itself. I have hit a wall at full speed. Any suggestions would be awesome.
Sean,
I'm running 2010 so I could only look at your assembly with e-Drawings. Based on that, and your description I'm wondering if this is sort of what you're looking for?
If so could you elaborate as to how you were wanting the mesh to wrap around the ring. That will likely prove to be the hard part.
If this is not what you are looking for, can you give more info and maybe a picture of something similar.
Erik
