I have a drawing of a weldment in SW2010 and the weights are showing up different in the cut list than they do in the cut list properties of the weldment part.
how different are they?
Problems of this nature often fall foul of the "as-machined" and "as-welded" configurations. Switch to the as-welded configuraion in the model and check the weights to see if they are the same as the drawing. You can then check to see if there are feature differences between the two configurations.
Welcome to SolidWorks forums Krish.
Right click on cutlist in part mode and select update and then check in drawing.
In case problem is still there, please upload some picture or files to test.
You might also find this post helpful for your future reference
