I seeking how to get a 3D file showing only the exploded state of an assembly
- Can an assembly be saved with only the exploded configuration ?
- Can an exploded assembly be exported as part or as parasolid, or IGS, or ... ?
Good morning Erwann,
If you explode an assembly those changes stay in the file, I'm not sure why you would need to have it saved with only a exploded configuration. When you explode an assembly those changes remain in the file.
Yes you can save an exploded assembly in a iges format,
Later,
John
Thank you, John,
I have just tried and it works very well in iges format on an assembly made of 2 parts
But I tried on a bigger assaembly (about 50 parts): SolidWorks makes the IGS files, but when I try to get back SolidWorks Files from these IGES files, SolidWorks fails after creating half the part files and no assembly
I wonder if there are parameters to define when exporting/importing via iges files
I just did a small assembly of 10 parts and it worked well, I might be able to look at a larger assembly later. It should work just the same, except the computer processing speed, you may have some issues there.
Defining parameters;
When doing the save as, check on the options button and make some changes there and see what happens,
Later,
John
Later,
John
