Hi guys
I'm new to Solidworks and I have a problem with configurations.
I made a model and I want it in different sizes(configurations).
But when I change one of the configuration the rest of the configurations also change!
How can I solve this problem?
the dim you are changing is likely still set to "all configs"
option A) right click on the dim and select configure dimension. this will give you a table to enter values for each config, and allow you to add configs.
option 2) when you double click on the dim to edit it, click on the icon in the lower right that looks like a list of configs. this gives you a dropdown to select the scope of the change.
