May not be the answer your looking for, all I did was added a radius on the 45 deg bend. In your base sketch you had it a sharp corner, so I just added a 3mm radius and it works ok. Could be something with that thickness and degree of bend that makes it not want to hold out.
Glad you got it working. I just flat out ran out of time to take a closer look into it. I was going to make a part from scratch to see if I get the same results, but......
Good morning Steven,
Later,
John
