Something strange has happened to my solidworks today. Whenever I want to create a circle in an extruded boss it automatically assumes I want to make an extruded cut of this circle. I don't want to make an extruded cut of this circle, I actually want to extrude it but because of the cut I can't. On Feature Manager it says there has not been an extruded cut but there quite clearly has been, meaning I can not delete the cut. If anyone knows how to fix this and if I need to reset any settings and so on, I would appreciate a reply.
Thanks once again,
Harvey
Can you attach what you have. When you created the extrude did you have the circle in the same sketch? If you create an extrude that has a closed contour inside of another solidworks automatically create a voi there. If this is the case you can use the contour select tool to select what you want to extrude and not extrude.
