I was sure someone has asked this, but I just can't find it. Maybe I'm searching wrong. Anyway...
I've got a part that has two configurations with two different materials. We let Solidworks generate the part weight based off of those materials using a custom property for each configuration and the "mass" value. Is there anyway to get both of the weight values to show up on the same drawing without having to type one of them manually in?
If you place the views in two different sheets, it will automatically populate the configuration specific properties
The properties filled in from the first view in a sheet.
If you place the views in one sheet, you can create an annotation and place on each view and it will populate the properties of each view.
Hope this helps
