I planning to cut a paper and build them into a funnel.
The each surface of the funnel is curved surface; therefore, the side view of this part is different with actual model.
I tried to use sheet metal option, but I it does not work.
Would you please give me some idea to conver this curved suface into 2D paper format drawing?
Thank you and happy holiday
Hi Park,
Why you are not using the Lofted bend option for this.. just covert the upper and lower edge sketch entity and then give them a thickness by lofted bend command and then get blank for this.
Regards,
Satish Kumar
