CFChris Ferguson19/12/2011
We take a dxf from the model and send them to a water jet. The water jet will cut out the holes per the dxf, so I created my own standard and customized the socket head cap screw hardware. I am able to set the diameter of the thru hole, for close, normal and loose, but for the counter bore diameter, I only see one size setting. Is there a way to set different diameters for the loose, close and normal options within the standards.
