I am modeling up several asbuilt piping spools and in many places the elbows are welded directly to the flanges or tees etc. Is there a way to run the route without putting short pieces of pipe in between the two fittings? The closest I have come is to specify only a 64th of pipe length and then make the line construction so the piece of pipe is gone but this is very much a "work around"
Yes - you route initially with a pipe in between, then RMB the straight section of and select "Remove Pipe". This will add the appropriate dimension to all SW to think there is no pipe between the fittings.
Cheers
Merry
