I am trying to insert the intersection point where two lines are filleted. Where I worked before this was set up to be a keyboard short cut and I don't know what command to apply the short cut to. Can anyone advise what this is called?
I was trying to figure out what the OP meant by two lines having fillets as in two filleted lines as in... how does an interection come into play here, are the two arcs crossing...
Since you put this in the sketching area, I am going to presume you are in a sketch. But it's the same thing in a drawing.
Ctrl-select the two lines and hit the sketch point icon. The term for which you ask is Virtual Sharp and you can set how it looks in the options..
WT
