Hello out there.
I´m from Germany and I work in a litle company. Since the last view month we work with SW 2011 and Enterprise PDM. It all works - but we have one problem.
The drawings, witch where build in SW11 should be plotted in eDrawings or Solidworks-Viewer. Because our planing operators have no Solidworks on their Computer.
The problem is, that the demonstration in those both software is different to the Solidworks demonstration ! The plots have a view misstakes. The line width, the kind of line and the parametes from the blocks are wrong. The hotline/helpdesk from our "Help-Company" has no solution. So is anyone out there who has an Idea or a solution ? Maybe a other software for plotting SW-drawings . . . ?
Thank you ,
greets Dirk F.
Welcome to SolidWorks forums Dirk.
You can also generate PDF (either using save as PDF option or print PDF option) and then send them the PDF file to view/print.
You might also find this post helpful for your future reference
