I am trying to write an API macro to connect to an access mdb database (autonumber.mdb). It has one table (tblPartNumbers), with 4 fields (Partnumber, Description, Date and Drafter.
I have the connection working for the most part. (borrowed from a macro I found on the internet), but I can't seem to get the SELECT MAX() (but I'm not sure if VBA even implements it...)
So, this is what I have working.
Public Function GetDocNumber() As String
Dim partNumber As Integer
Const dbPath As String = "(fill in your own path here)\Autonumber.mdb"
Dim ConString As String
SwApp.SendMsgToUser2 "Debug: GetDocNum Called", swMbInformation, swMbOk
ConString = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & dbPath & ";Persist Security Info=False"
'Initialize the connection object
Set cn = New ADODB.Connection
'Set the connection string
cn.ConnectionString = ConString
'Open the connection to the database
cn.Open
'Initialize the recordset object
Set rs = New ADODB.Recordset
'Obtain the recordset through a hard-coded SQL query.
Call rs.Open("SELECT tblPartNumbers.Partnumber FROM tblPartNumbers WHERE (((tblPartNumbers.Partnumber)= 'X1000'));", cn, adOpenDynamic, adLockOptimistic)
'Obtain the partNumber from the recordset
partNumber = rs!PartNumber
SwApp.SendMsgToUser2 "Debug: partNumber = " & partNumber, swMbInformation, swMbOk
'Clear Connection for other users
Set rs = Nothing
'Make sure you close the connection as Access has a maximum number of connections supported at one time (5 I think?).
cn.Close
Set cn = Nothing
'Set functionVariable equal to partNumber to ensure that the string is returned to the calling procedure
GetDocNumber = partNumber
End Function
The above command will pull only the record that contains the Partnumber X1000.
The problem is, I don't want to find a specific part number, I want to find the highest. I can't get the MAX command to work properly. I don't know why. No error messages that I can see, it just doesn't pull a record, and kicks out of the function without anything as far as I can tell.
I've tried a couple of other methods, but none of them seem to work.
A couple of alternatives I have been thinging about is:
Max command (that doesnt work right)
Call rs.Open("SELECT MAX(tblPartNumbers.PartNumber) AS Partnumber FROM tblPartNumbers ;", cn, adOpenDynamic, adLockOptimistic)
Or Sort in Decending order and pull the Top Record
Call rs.Open("SELECT TOP 1 tblPartNumber.PartNumber FROM tblPartNumbers ORDER tblPartNumber.PartNumber DESC ;", cn, adOpenDynamic, adLockOptimistic)
Again, both of these just bomb out without pulling an actual record. Any suggestions?
Thanks in advance,
Mike
(Note: There may be typo's in the above code I just changed some of the names on the fly to make it more readable, I appologize)
