Hi there,
I'm successfully using this wonderful macro posted by Josh Brady:
Sub UpdateQtys()
Dim swApp as SldWorks.SldWorks 'added this line
Dim Assembly as ModelDoc2 'added this line
Dim myAsy As AssemblyDoc
Dim myCmps
Dim Cfg As String
Dim CmpDoc As ModelDoc2
Dim i As Long
Dim j As Long
Dim cCnt As Long
Dim NoUp As Long
Dim myCmp As Component2
Dim tCmp As Component2
dim tm as double
tm = timer
Set swApp = Application.Sldworks 'added this line
Set Assembly = swApp.ActiveDoc 'added this line
Set myAsy = Assembly
If Assembly.ConfigurationManager.ActiveConfiguration.Name <> Assembly.CustomInfo2("", "Cfg4Qty") Then
Assembly.Extension.ShowSmartMessage "Qtys not updated due to config", 1000, True, True
Exit Sub
NoUp = 0
myCmps = myAsy.GetComponents(False)
For i = 0 To UBound(myCmps)
Set myCmp = myCmps(i)
If (myCmp.GetSuppression = 3) Or (myCmp.GetSuppression = 2) Then
cCnt = 0
Set CmpDoc = myCmp.GetModelDoc
Cfg = myCmp.ReferencedConfiguration
For j = 0 To i 'originally was "For j = 0 To UBound(myCmps)", I just changed it to make it faster, and it works (Riccardo)
Set tCmp = myCmps(j)
If tCmp.GetSuppression <> 0 Then
If tCmp.GetModelDoc2 Is CmpDoc Then
If tCmp.ReferencedConfiguration = Cfg Then
cCnt = cCnt + 1
Next j
CmpDoc.AddCustomInfo3 Cfg, "AutoQty", 30, ""
CmpDoc.AddCustomInfo3 Cfg, "QtyIn", 30, ""
CmpDoc.CustomInfo2(Cfg, "AutoQty") = cCnt
CmpDoc.CustomInfo2(Cfg, "QtyIn") = Assembly.GetTitle & " Cfg " & Assembly.ConfigurationManager.ActiveConfiguration.Name
Else
NoUp = NoUp + 1
Next i
Assembly.Extension.ShowSmartMessage NoUp & " Parts not updated due to lightweight (" & timer - tm & "s)", 10000, True, True
end sub
Well, it works great, and I'm using it a lot, since it does what I was looking for from years: it calculates the quantities of parts in an assembly and writes it down into configuration-specific custom properties.
1) Here comes a subtle problem. It writes down the quantities in configuration-specific custom properties, but many of my drawings are already linked to general custom properties or to DefaultFlatPattern custom properties. How can I make it write the same property (AutoQty) into general custom properties too?
2) For large (100+ components) the cycle becomes really slow: is there a way to make it faster? I already made a modification, but it's not fast enough...
Thank you for your collaboration and best regards!
Riccardo
