I'm getting loads of files as IGES files or Catia files. Can anyone help how to edit them or see dimensions of item. I'm working on "featureworks", but it not regenerate any feature.
Srea,
If you bring them in as IGES files then all you will get are dumb solids. Meaning
no features and no dimensions. Depending on what the parts look like featureworks
works best on straight forward machined type parts. Doesn't work well with curvey surface
type parts.
If the files are coming from Catia directly then you can open them up directly in Solidworks.
You still wont end up with dimensions, but at least you will have features that
you can go through and dimension.
Your option would be to use the measure tool
OR
Try one of the add-in listed here: Import files for SolidWorks
