I just moved to a coworkers desk. Is there a setting for when you click down the scroll window to rotate the model? For some reason on my computer it works great and on the other it moves far to slow to be of use.
Thanks!
Thanks!
The only brand of mouse that I know of that has a default middle button is Logitech. Check to see if you have the Logitech Setpoint application in your taskbar notification area (bottom right), and open up Setpoint. From there, you can assign different commands to specific buttons. Below is what mine looks like.
Ok here is the deal. I do have the logitech setpoint, because sometimes I use a logitech with a trackball. My other mouse is a microsoft. I see where you can set different tasks for what each button does, but that isn't the problem. The task works, it just is extremely slow. When I click on an object in SW and try to rotate the object it is extremely slow. I am trying to make it rotate at a reasonable speed.
Thanks guys
Check to see if there are any newer drivers for the mouse in question.
