I have some print tasks set up. However, when I select a group of drawings to batch print, the task does not seem to send them to the printer in any kind of order. It would be nice if it could sort by the filename and print in order. Any ideas?
Our VAR made an add-in for EPDM and our drawings are printed in order now. The order we use is according to the tree structure. They also build in a lot of options, like: Header/footer text; Type of printer depending on sheet size; Printing paper size depending on sheet size; Pdf/dwg/dxf/eDrawing export; Reverse printing order. This is a nice tool, which should be standard in EPDM!
The XnView program can be of real interest to those who have no Add-ins.
At the same time the program is absolutely free and is automatically built in context menu PDM.
I use XnView version 2.42 with the ghostscript module for PDF (gs854w32.exe).
There is both a sorting and batch print with a choice and convenient viewing and many other things.
For big formats it is possible to use PDFXChange.
Can do it not absolutely on a question subject, but can be of interest to someone.
I am using CustomTools for printing instead of using PDM print functions since it lets me print in order
Document Creator from ToolWorks is very god add in for SolidWorks and PDM, But it is expired.
It could, with a simple mouse click, sort all drawings in numerical order and merge them in to one pdf file. I can still use it, but the problem is that, we can not get more support for it.
Now I'm testing PDM print task. It runs fine, but without sorting. I will miss my good document creator.
Hey Mike,
Good to see you. We recommend Flatter Files to all our customers. Not only does it publish your drawings to PDF automatically upon release, it also allows you to print drawing packages in the order you specify.
Watch our Youtube video. Flatter Files - Print drawings in order - YouTube
Publishing drawings to Flatter Files also carries data card fields with it, maintains attached reference trees, creates assembly views, and more. Big name companies like Muncie Power Products, Vermeer Corporation, Kimray Corporation, Makerbot, etc. are using this solution for their PDM content distribution needs.
Tim
This is a real problem. Even the sheets of a multi-sheet drawing aren't print together!
Please SW improve this!
We have projects with a several hundreds of drawings and it takes hours to sort the paper drawings.....
