How can you export a single part out of an assembly file in .igs format?
Hide/Suppress the parts you don't want to export. To do this quickly, select the one you want to export, then right click and select invert selection. This will select the components you don't want to export./ Now do save as IGES and you'll be prompted to show/unsuppress those componenets . Hit NO and then continue. This will create the IGES files with required componenets only.
Open the part file up and Save As, select iges in the Save As Type dropdown.
Cheers,
Anna
