I need to import some parts created in ProE 2001 into SW 2012. I have tried importing one part so far, first as a ProE import and then as a STEP file and am encountering problems with both methods. Before I waste time describing the issues can anyone tell me if the ProE and/or SW versions are a problem? Thanks.
Robert,
Welcome to the forum.
The problem may be more that Pro-E 2001 is not compatible with 2012.
If I remember correctly parasolid works better as an export out of Pro-E.
Did you try that?
