Open the thermodynamic properties option closer to the bottom of the Flow Rate BC definition. This pressure is only an approximate pressure, defaults to your ambient/environmental setting, because you cannot set a pressure and flow rate at the same time.
Set another boundary with a pressure and this will help set the state of the fluid, and with it you can find the pressure differential to the flow rate by setting a Surface Goal of pressure on the flow rate face. Use an Equation Goal to subtract the calculated pressure at the flow rate face from the ambient pressure (hint: select the Input Data folder on the tree and then it will present you a list of conditions set for the environmental conditions in the Wizard).
