I'm trying to cut a tapered hole through a 3 part assembly for a pin. It's at a rather strange angle, thus I decided to perform the cut while in assembly. However, the cut is not applied on a part level, and moving the assembly around changes where the hole is cut.
Is there anyway to set this cut on a part level, saving me the trouble of ensuring concentricity with a varied diamater accross each part?
The part also has to be scalable easily, since it will be required in various sizes (another problem I believe the assembly cut would cause problems with).
Will be greatful for any help,
Propagate feature to parts seems like the option I'm looking for. For some reason it doesn't seem to be working though, the cut is displayed fine when unchecked, then disappears when propagate feature to parts is selected.
