i made a assembly and used pack and go and saved in other drive. after some time i made an other assembly and used one of the part that was used in earlier . but i did not poicked it from that folder which i saved with pack and go. i modified and changed bit in that and it was also changed in that assembly which was packed. what i can do?
Ali,
I'm a little confused by your description, but I'm pretty sure that your problem is showing you the importance of not having two different files with the same name.
If it's not too hard to change the part that you saved back to the original format, open the assembly where you want the old part. Be sure that the assembly where you want to keep the new part is not open. Save the part with a new name. This updates the references in this assembly to point to the new part. Modfy the part back to the old style. Save it.
If you want the old part to keep its name, then you will need to close the assembly where you want the old part and open the assembly where you want the new part and save the part with the new name. This updates the references in this assembly to the new part. Then close the assembly with the new part and open the assembly where you want the old part. Edit the old part to go back to the old style. Save it
Jerry Steiger
