CRColin Russell04/12/2011
Hey,
If anyone can help me it would be much appreciated.
I am trying to perform a transient pressure pulse analysis on an intake that I designed. I watched a video on youtube and then tried it myself however I cannot get it to work properly.
I have made an excel sheet with time v pressure tables for each of the four cylinders. I then selcted environmental pressure for the inlet and time dependent environmental pressures for each of the outlets by pasting in the relevant excel values for each outlet. I then made a series of goals and asked it to run however when it has finished solving I am unsure of how to get the reults to show correctly.
I have created flow trajectories for each opening (1 inlet and 4 outlets) and these show the flow to be going in the wring direction except for one outlet which is showing a pressure drop. I tried to animate it but this has not worked either.
I am also unsure how to slow down the animation as the event across all four cylinders happens in 0.12576 seconds.
Any help would be much appreciated as I am new to flow simulation.
Cheers
Colin
