I have made metal construction of solar system.
I would like to make simulation study - see attached files.
I do not have experience in simulation. I add material, fix geometry, load and when I create mesh - mesh failed.
Can anybody help me?
Thanks in advance.
Zdravko,
I'm not very knowledgeable about SW Simulation, so I can't help much with your mesh problem, but looking at the picture, I would think that you would be much better off running a beam simulation instead of a solid simulation. The next option would be to simplify your model to surfaces and then use shell elements. This may get a bit tricky where you join the pieces together, due to the offsets.
Jerry Steiger
