Has anyone to give me some information about customizing the BOM?
I would need to appear in BOM the follow columns: Mass (of every part) and Material. From other part I need to change the head of every column (translate in other language) - is possible?
I read the tutorial where the examples are very easy, but in real situation there are big differences.
Thank you for yours answers.
Mirel
You can easily add columns for mass and material. After creating your BOM table, right-click on a column header and insert a new column to the left or right of the existing one. You'll get a new column and a small dialog with choices for what information will appear in the column. Select Custom Property and then under that control, there will be a list from which you can select "SW-Mass" or "SW-Material"
You can rename any column header by clicking on it and typing a new name, so translating them to a different language should be a simple matter.
I'm not at my CAD station, so I can't verify all of the steps, so give it a try and report back here if you have any issues.
John
