I am working on a flow simulation for a device, there are totally two flows in two areas of one device. One of fluid impacts on the radial turbine blade, another is a vaccume inside of turbine shaft. Can I do it in solidworks? How can I do it?
Thank you for the help!
Kehui,
It would be helpful if you would post a .jpg depicting the model you wish to the Flow simulation. In Flow you can establish a "fluid subdomain" allowing you to use two different fluids. I do not know if this is possible with FlowExpress if that is your case.
