When I create an electrical harness with the SW routing program, the "Route Parts" folder is not created. When I exit the Edit Component mode, my wires dissapear, even though my components are still visable. In the feature manager tree, under my harness subassembly, there is a "Components" folder that contains my components, a Route1 feature that contains my 3D sketch, but no Route Parts folder is created, so when I exit, the wires are not created, even though the 3D sketch has the correct path and I can see it when editing. I have tried looking at all my settings and recreating the harness over and over, and the same thing happens every time. I can go to another computer here at work and create harnesses just fine, but on my machine this happens. Anyone have any suggestions?
Thanks!
I fixed the problem, reset my default templates under Tools, Options, Default Templates. Now Route Parts folder shows up and wires and cables are routing properly. Routing seems to be touchy when it comes to templates.
