I want to perform structural analysis on a plank I am designing for my engineering design course. Unfamiliar with SolidWorks, I constructed the model in Rhino. I performed analysis on all objects of the Rhino model showing that there are no exposed edges (all polysurfaces are closed). In addition, I set my model tolerance to .00001 so each object in my model should be airtight. However, when I import my model in to solid works, solid works is treating the model as if it were a single object, showing many errors due to "unmerged" object faces. I do not want to import this model as a single object, I want to import the model with each object as its own entity to analyze the structure appropriately. Is there an efficient way to do this?
Thanks for your help,
Leonard
P.S. I have attached the .3dm file for viewing.
