Hi, i have applied a clear plastic appearnce to a component, i want the glass to be as it says, Clear, but when i am working in solidworks the plastic has aload of square lines running through it, when i render i photoview 360 the glass then appears clear without the lines.
How can i achieve the clear plastic to be clear when working in the solidworks model itself.
I have attached a pic
thanks
Can you upload the part? Or a sample part with the same problem.
Also, what are your system specs.
