I'm trying to simulate gravity acting on an assembly that is a length of steel link chain. I've set up the chain, and also a body for it to fall over top of. I can get gravity working no problem, but I can't get the Contact feature to work - the chain just falls through the body I want it to fall on top of.
Can anyone help?
I dissolved your sub assembly and pattern group and floated the fixed link. Use motion analysis. Set solver under optionans/advanced options to WSTIFF.
Box select all the parts and make the contact group. You only need to run analysis for 0.5 sec. as it is extremly slow to solve.
