Charles Culp
November 2011 Suggested Computer - Ultra-high Performance
Discussion created by Charles Culp on Nov 18, 2011
Latest reply on May 11, 2012 by John White
* Note that this hard disk reflects current pricing due to the shortage of Hard Disks due to the flooding in Thailand. Hard Disks are twice the price they were two months ago.
I have decided not to revise my October suggested system, as that is still mostly current for what most people should consider for a CAD machine.
For some people, though, you want more. Lets say you make rendered animations all the time, and you want the most cores/speed possible. Earlier this week Intel released their latest Core i7 Extreme 3960X, which runs at 3.3 GHz, 3.9GHz turbo. Note that this is still a slightly lower clock rate than the Core i7-2700K, and it is not overclockable. If you still want the fastest computer for modeling, look at my October build with the 2700K. https://forum.solidworks.com/message/259572
For those of you who want to render, this is the king. In the spring, Intel will release their dual-CPU chips, and then those will be the render kings. Of course, they will also require a very expensive motherboard, with two very expensive CPUs. This setup has the new, and expensive LGA 2011 motherboard, but you only have to purchase one really expensive CPU.
This CPU runs at 3.3 GHz, 3.9GHz Turbo. It also has six cores, all hyperthreaded. This will give you 12 glorious virtual cores running at 3.3GHz; great for rendering. And all the speed optimization of the Sandy Bridge processors.
Total price? $2,433
So, without further ado, here is my suggested setup. Don't forget that the RAM for this is currently unavailable, so it is not in the table below. I assume it is just too new.
Qty.Product DescriptionSavingsTotal Price
Sony Optiarc CD/DVD Burner Black SATA Model AD-7261S-0B LightScribe Support
Sony Optiarc CD/DVD Burner Black SATA Model AD-7261S-0B LightScribe Support - OEM
Item #: N82E16827118040
Return Policy: Standard Return Policy
$19.99
NZXT GAMMA Classic Series GAMA-001BK Black Steel ATX Mid Tower Computer Case
Item #: N82E16811146061
-$14.00 Instant
$49.99
$35.99
Western Digital VelociRaptor WD6000HLHX 600GB 10000 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136555
$329.99
CORSAIR Professional Series Gold AX650 650W ATX12V v2.31 / EPSV12 v2.92 80 PLUS GOLD Certified Modular Active PFC High Performance Power Supply
CORSAIR Professional Series Gold AX650 650W ATX12V v2.31 / EPSV12 v2.92 80 PLUS GOLD Certified Modular Active PFC High Performance ...
Item #: N82E16817139035
-$20.00 Instant
$169.99
$149.99
GIGABYTE GA-X79-UD3 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813128532
Return Policy: Limited Replacement Only Return Policy
$269.99
Intel Core i7-3960X Extreme Edition Sandy Bridge-E 3.3GHz (3.9GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73960X
Item #: N82E16819116491
Return Policy: CPU Replacement Only Return Policy
$1,049.99
ATI 100-505606 FirePro V4800 1GB GDDR5 PCI Express 2.0 x16 Workstation Video Card
Item #: N82E16814195096
Return Policy: VGA Standard Return Policy
$159.99
Rosewill RFX-120 120mm Case Fan
Item #: N82E16835200021
$17.98
($8.99 each)
Intel 320 Series SSDSA2BW120G301 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
Intel 320 Series SSDSA2BW120G301 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD) - OEM
Item #: N82E16820167068
-$20.00 Instant
$219.99
$199.99
Subtotal:$2,233.90
Shipping:$19.08
Plus, you need RAM. I suggest DDR3-2133. It is not cheap (nor even currently available in quad-channel). So when it is available, here is what I suggest:
$179.99
I go into much more depth in my "suggested october build" thread, but here is a summary of why I picked this:
Intel SSD: SSD's are a must for a high performance machine like this. Intel's are the more reliable SSDs.
Cosair 650W Gold rated power supply: This thing takes quite a bit of power, so a higher efficiency power supply will pay for itself in electric consumption.
Motherboard: The LGA 2011 motherboards are new. I picked the cheapest one from one of my favorite brands (I only spec ASUS or gigabyte).
Memory: DDR3-2133 is fast! Expensive, but this is "ultra-performance", right?
Case fans: 1 80mm front and 1 120mm rear come with the case. 2 additional 120mm fans will help cool that high-speed memory, and protect that expensive CPU. The case can hold up to 4 more, so buy more if it suits your fancy (probably overkill).
ATI v4800: I'm still of the opinion, even for an ultra-performance machine, that these are good enough. If you like overkill, the ATI FirePro v7900 is smoking fast.
