Hi all.
I have a problem after installing E Drawings 2012 on a couple of the computers in my company it wont open
SLDPRT files or anythings else there have to do with 3D files.
Every times i make a file association so a specific file should open in E-Drawing it just change
the icon to PDF's file format and that is all there happens.
I actually have the same problem in one of our Full Solidworks Licenses. All the machines i the problem with runs Windows XP
I have had a this problem with another program and the way I was able to fix it was I used the folder options and deleted the file extensions from the association tab then close this and brouse to one of the files who's file type you just deleted and select it. Then hold down the shift key and right click on the file. Select Open With_... and select eDrawings from the list. If it is not in the list then select the browse button and browse to the eDrawings.exe and select. Make sure that the check box is selected to Always use this program to open this type of file. This should reset the file association to eDrawings
