Hey all,
i am trying to get to grips with using Photoview in soldiworks. I am having diffulty getting to grips with using the hdr enviroments (the tutorials make it look so easy!). Anyway the difficulty im having at the moment is that when i load my photoview i do not get the same window that i see in all of the tutorials? my window is the top image, the tutorial image is the bottom). These tabs appear to hove some sort of advantage, as when i watch the tutorials the user is able to rotate the view whilst it is preview rendering, and can also adjust the environment accordingly. The closest i get to this is to pull the preview window to the side and twist it about in the back ground, which is quite irritating and takes longer.
Any ideas?
Cheers,
Luke
That's because the tutorial is done in 2010 and it looks like you are in 2011. In 2011 PV360 was integrated inside of SW. In 2010 it's a standalone application.
You do have different preview options in 2011. You are using the preview window option. If you choose the Integrated preview option (icon on render tools toolbar) the entire SW graphics area will become the preview and it will work much the same as it does in 2010.
