Not sure why, but I suspect that because the edges are beveled all around, no bends are identified when I use "insert bends" to convert it to sheetmetal.
It is an imported STEP file that is intended to be bent from 11ga CRS.
Are the beveled edges the problem?
Any easy fix?
Those beveled edges are problematic but aren't a deal breaker, you just can't use "Collect All Bends" when you convert. Manually select a base face, then manually select the two bends.
